Dry Shot + LG GX51 Cam
Old Sep 25, 2006 | 05:04 PM
indygoat's Avatar
Default Dry Shot + LG GX51 Cam
Before I pull the trigger on a Dry N20 setup I just wanted to run this by you guys real quick. Im new to Nitrous, so forgive me if Im missing something...
Currently I am running a LG Motorsports GX51 cam specs are 228/232 .588 .574 112 LSA. I would like to know what you guys think is a reasonable shot size with that cam on an otherwise stock fuel system.
Old Sep 25, 2006 | 05:59 PM
Matt@HSW's Avatar
Around how much is she making NA? I'm going to say not too much with a dry system on the stock injectors.
Matt
Old Sep 25, 2006 | 10:00 PM
indygoat's Avatar
She is doing 375rwhp on cam only, so you think a 75 shot is doable, or will I run out of injector?
Old Sep 26, 2006 | 07:13 AM
charlie c5's Avatar
You can do a 125 alllll day long. I have done this on many customer's rides, with a few more mods then you, and they ALL are still living. Change your plugs, have your tune checked, and you'll be fine.
Old Sep 26, 2006 | 09:39 AM
Matt@HSW's Avatar
You might squeek by on a 75, it will be very close. The only way to know for sure would be to log your injector duty cycle, which I would suggest doing if you can.
Matt
Old Sep 26, 2006 | 10:53 AM
NicD's Avatar
7 Second Club
450 rwhp is about max in an all motor app that the stock ~28 lb injectors can provide. When you spray, you will want to run slightly richer than on motor so I would say you would be able to spray 50-75 and you will max out the injectors and start to lean out. Get some new larger injectors and go to town though.
