Will the timing tuner work for my plans?
Old Oct 5, 2006 | 12:31 PM
fastGBcamaro's Avatar
Default Will the timing tuner work for my plans?
Im kind of a N2O newbie but Im planning on adding a 200 shot to my H/C car. I plan on running a stand alone fuel system and all the other safety stuff. I was just wondering if I could connect the timing tuner up to my N2O activation switch so that every time I turn on the kit a specific amount of timing will automatically be pulled? Then when I turn off the N2O the timing will go back to where ever I have it set for NA. If the timing tuner wouldnt work for this is there anything out that would work for this?
Old Oct 5, 2006 | 12:33 PM
Phlip00WS6's Avatar
Yes the timing tuner will only pull timing when the nitrous is armed... You could also use one of the many ignition boxes out there.
Old Oct 5, 2006 | 08:59 PM
1BADAIR's Avatar
if its wired like they want it to be it will only pull timing with the noids on
Old Oct 6, 2006 | 09:03 PM
sprydncamd ta's Avatar
i run the timing tuner and the harris speed works stand alone fuel system with a 250 shot without any problems the timing tuner activates with the nitrous and vice-versa
