is anyone spraying with flycut pistons?
Old Oct 6, 2006 | 06:31 AM
import slayer's Avatar
Question is anyone spraying with flycut pistons?
My mods are in my sig and I did a search already and could not get a good answer, when I put the t-rex in I had to flycut my pistons. Is it safe to spray with flycut pistons and also what are the effects of spraying with a 4400 stall. I am only looking at a 75-100 shot and I am thinking about getting the TNT F1 wet kit. any advice
Old Oct 6, 2006 | 09:17 AM
Matt@HSW's Avatar
You should be okay spraying the flycut pistons, depending how much was taken off. How much did you take off on the intake/exhaust?
Matt
Old Oct 6, 2006 | 01:40 PM
BlueThunder2's Avatar
I'm running 11.5:1 compression, 2.05/1.60 valves, big cam, fly cut pistons, and the NX maf kit with 150 shot, without any issues. Getting ready to step up to 200 shot.
If you spray with that stall, you will see every bit of that stall speed, maybe even a little bit more.
Old Oct 8, 2006 | 12:18 AM
What shot should I use with that converter I was thinking a 100 but I am not sure?
Old Oct 8, 2006 | 10:05 AM
100 Should be fine. You shouldn't have ana issues wit the stall, or motor. Rearend could be a problem though.
Old Oct 8, 2006 | 10:47 AM
sleeperstyle's Avatar
you can spray a car with any stall in it, but it may not be optimal. i'd think you would spray right through it with anything over a 100 shot. flash to like 5500rpms and have a shift extension close to 6k possibly. a bigger tire will bring it back down though
Old Oct 8, 2006 | 03:24 PM
thanks for all your advice.
