n2o and window switch?
Old Oct 8, 2006 | 06:38 PM
02NBMWS6's Avatar
Default n2o and window switch?
how would i do it, or is it possible to setup my n2o to activate when i release the clutch when using a window switch holding the revs to 3-3200 on launch?
what i want to do is have the revs held at 3k on the window switch at WOT and then when i dump the clutch have the nitrous system activate.
how do i do it?
Old Oct 8, 2006 | 09:19 PM
02gixxersix's Avatar
I would guess that after the initial RPM drop if you have the WOT switch and window switch as soon as you are at WOT and 3000 rpm it would kick in
Old Oct 9, 2006 | 10:12 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
how do i do it?
You would need a 2 Step....it would hold the preset RPM then when the 2 Step disengages it would activate the N2O
Old Oct 9, 2006 | 12:05 PM
02NBMWS6's Avatar
duh, i meant to say two step, obviously the window switch was on my mind.
how would i set a two step up to activate the n2o as it disengages? thats exactly what i want.
Old Oct 9, 2006 | 02:04 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
The 2step automaticaly cuts power to the kit when it is engaged then when you launch it turn the kit back on.
