A4 window switch or not
Old Oct 13, 2006 | 06:27 PM
MooresGTO's Avatar
Default A4 window switch or not
I have an automatic, was wondering if you would use a window switch or not.
Old Oct 13, 2006 | 06:45 PM
~RedLineLs1~'s Avatar
I run one...Anything that can help prolong the life of the transmission is worth it IMO.
Old Oct 13, 2006 | 11:38 PM
SSDoubleK's Avatar
Yes, spraying threw shifts is hard on the tranny.
Old Oct 13, 2006 | 11:43 PM
TWS's Avatar
TWS
YES! Don't want to spray too low and you also want to cut off the spray before your motor could hit the rev limiter. If the tranny were to let go in the middle of a pass, you don't want the motor hiccuping against a rev limiter when spray is involved. In other words, you don't want a blown tranny to take the motor out with it.
Old Oct 14, 2006 | 08:16 AM
MooresGTO's Avatar
Sweet guys, thanks for the advice.
Old Oct 14, 2006 | 11:16 AM
nate-roth's Avatar
Check out the trick performance one available through nitro daves. It is a window switch and tps switch in one unit. Super easy to use, I change my window switch settings at the track all the time in about 30 seconds. All digital, no resistors or anything. It costs around $130.
