***help With Nitrous And Fuel Pump!!***
Old Oct 15, 2006 | 06:12 AM
01arroyo's Avatar
Default ***help With Nitrous And Fuel Pump!!***
WELL OK I INSTALLED THE NITROUS ON MY 99 A4 I HAVE A 75 SHOT IN IT AND WELL I WENT TO TRY IT OUT AND I SPRAYED IT AND IT TURNS OUT IT MESSED UP THE FUEL PUMP. IT WAS OUTTA GAS SO I THOUGHT THAT WAS THE PROBLEM. I BOUGHT A NEW FUEL PUMP AND FILLED THE TANK UP WITH GAS SPRAYED IT AGAIN AND MY FUEL PUMP MESSED UP AGAIN. THE PUMP WAS INSTALLED PROPERLY. WTF!!!!!!!!!! HELP!!! WATS THE PROBLEM HERE. I GOT THE LINE DIRECTLY PLUGGED INTO THE FUEL RAIL.
Old Oct 15, 2006 | 08:25 AM
mrr23's Avatar
where are you tapping in to supply power to the nitrous system?
Old Oct 20, 2006 | 04:51 PM
01arroyo's Avatar
im tapped into the battery i have not touched the fuel pump for nothing. I still cant find out whats causing my fuel pump to take a dump everytime i hit the nitrous
Old Oct 20, 2006 | 05:12 PM
brad8266's Avatar
Do you haver a new filter in there?
very well sounds like it could be wiring.
Wait heres another question, dont get offended. Did you take the schrader valve out of the fuel rail port before you connected the fuel line to the rail?
