rpm window switch question
Old Oct 19, 2006 | 01:54 PM
firebirdls1us's Avatar
Default rpm window switch question
Does anyone have there window switch hooked to the wot switch to cut off?
If not where is the best place to hook it and I'm running wet kit...
hxs. Robert
Old Oct 19, 2006 | 04:12 PM
sonicbaloo's Avatar
Which window switch are you using?
Chad
Old Oct 19, 2006 | 05:10 PM
msd p/n 8956....okay I just found it on a sticky up top......looks like the fpss is where it needs to be correct?
Old Oct 20, 2006 | 04:51 PM
SSONE's Avatar
mine is on the wot
Old Oct 20, 2006 | 06:48 PM
okay so it does have enough current to make it work then......thats good
Thxs..
Old Oct 22, 2006 | 08:42 PM
birdman97lt1's Avatar
directions included w/window switch and the nitrous system should give you enough information to install it is a simple relay and trigger ativation.
Old Oct 23, 2006 | 05:17 PM
I can tell you don't and have'nt installed one ona ls1 then ..........because I have used the so called instructions and it dont work peeker head
