WOT switch with 80mm TB
Old Oct 19, 2006 | 11:19 PM
BigDB's Avatar
Default WOT switch with 80mm TB
Iv tried to mount the switch but i broke it bending it so much to fit. I saw that a sponsor has custom mounts for the stock TB and the 90mm ones but im running the 80mm so I dont know if either will fit. Any advice thanks
Old Oct 20, 2006 | 01:11 AM
gmpower's Avatar
i made a bracket out of a home interior light switch i had lying around. took off the metal bracket where you screw it to the wall and bent it, and mounted the WOT. works perfect.
