Timing tuner configuration ?
Old Oct 21, 2006 | 11:31 AM
brians98ss's Avatar
Default Timing tuner configuration ?
Got a couple of questions concerning the green and red LEDs on the timing tuner. FYI, I'm only using the tuner to pull timing when running nitrous, no timing adjustments when running off the bottle.
1. Should the green LED remain lit all the time whenever the motor is running?
2. When I configured the high RPM cutoff for the window switch, the instructions say the red LED will light for 10 seconds and then both green and red LEDs light for 1 second. I had both LEDs light up for a second but the red did not come on for 10 seconds (didn't come on at all). Is this a problem?
Thanks for any help.
Old Oct 22, 2006 | 11:45 AM
Matt@HSW's Avatar
1. Yes, it means the TT is reading a good crank signal.
2. We've installed quite a few, never got them to light up for 10 seconds but they always have the correct turn off programmed. Sounds like your ready to spray!
Matt
Old Oct 22, 2006 | 02:19 PM
1BADAIR's Avatar
I had the same question a mounth ago. both mine don't light up but it works fine
