How much $$ for install??
Old Oct 24, 2006 | 12:17 AM
Magnet's Avatar
Default How much $$ for install??
If i brought my car to a reputable shop let say revxtreme for names sake...what would they approximately charge to install a kit with all the goodies..FPSS, Wot switch, purge etc...would probably be a TNT f1 kit, but havent fully decided yet
Old Oct 24, 2006 | 12:29 PM
Magnet's Avatar
someone help..search isnt working...
Old Oct 24, 2006 | 01:35 PM
~RedLineLs1~'s Avatar
Kind of hard to tell. I was going to install the system myself but for ***** and giggles I called around for quotes. I was quoted anywhere from $300 to $600 for a dry kit, fpps, WS, heater, etc. To be honest, the installation isnt too bad. Its pretty straight forward. I would try it yourself and if it doesn't work out then take the car somewhere. JMO.
Old Oct 24, 2006 | 02:01 PM
Hennytime's Avatar
i hated the wiring, everything else was great
Old Oct 24, 2006 | 03:06 PM
94z28L's Avatar
for me wiring is a night mare and is what ill probably either give some buddies beer for or take it somewhere
Old Oct 24, 2006 | 03:56 PM
Todd157k's Avatar
It just isn't that tough.
1. Use color coded wires so when you route them, you know what you have.
2. Use push-on lugs so if you have to check it, it's easy to disconnect.
3. Use a ton of cable ties. Keeps everything neat and easy to route.
4. Use a 12v probe light BEFORE connecting to the switches. It's just double checking.
Old Oct 24, 2006 | 04:16 PM
Shodown's Avatar
I knew absolutely nothing about wiring before I put mine and I didnt have any trouble. As long as you are not color blind and you have access to tools you should be fine.
Old Oct 24, 2006 | 04:58 PM
BLCK PRL's Avatar
The install price not only varies but it goes up depending on how many gauges you have to install with it, ie. Air/Fuel ratio, N2O pressure, etc.
