A few questions
Old Oct 26, 2006 | 01:22 PM
96ta's Avatar
Default A few questions
Whats your opinion of the Nitrous Works LS1 Powerwing kit?
should i get new injectors to spray a 100 shot?
Whats the difference between a 5psi safety switch and a 30psi safety switch?
thanks
Old Oct 26, 2006 | 06:19 PM
sprydncamd ta's Avatar
you shouldnt need injectors depending on your other mods i always think an upgraded fuel pump is a must and i a bias to the harris speed works nitrous kits do to their great quality and affordable price so you can add accessaries like a bottle heater and purge for the same price as a basic nitrous kit would cost
Old Oct 26, 2006 | 09:03 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
I have not seen their power ring but they seem to have decent products. You should be fine with your current injectors with a 100 shot. The difference between the 5 psi and 30psi safety switch most likely is the 5 PSI switch is for Carbureted cars and the 30 PSI though typically set closer to 35 PSI is for fuel injected.
Good luck!
Dean
Old Oct 26, 2006 | 10:14 PM
96ta's Avatar
thanks.
