Best RPM Window Switch for my Setup
Old Oct 27, 2006 | 01:43 PM
ARCTICWHITE98Z28's Avatar
Default Best RPM Window Switch for my Setup
I recently purchased the HSW Sudden Impact Single Nozzle Dry Kit (LSX) and am wondering which RPM window switch would work best for me. I am planning on using the 100 HP jet.
The reason I am buying a RPM switch is because I have a stock A4 transmission in my 98 Z28 w/ 90,000 miles and I don't want to destroy the tranny by spraying through shifts. I have the following mods on the car: exhaust cutout, air lid, 3400 stall converter, tranny cooler, and drag radials. It currently runs and shifts great.
So I am looking for a switch that is easy to install, will work with my setup, and is inexpensive. Please let me know what you think. THANKS.
Old Oct 27, 2006 | 01:44 PM
BIG_MIKE2005's Avatar
I'm goin with the BMN, but I chose it for the first gear lockout feature.
Old Oct 27, 2006 | 01:59 PM
1st gear lockout definitely sounds like a nice feature. Otherwise traction would definitely be an issue. Even with DRs. I notice that a lot of guys seem to use MSD switches. Which of the MSD switches is better - the one that uses pills, or the digital RPM switch? THANKS.
Old Oct 27, 2006 | 02:26 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
We use to carry the MSD and no longer do. Long story... We carry this unit exclusivley now. It has window switch capability for one or 2 stages. It has a built in TPS switch so no need for a WOT switch - giving you a cleaner install - and it also has multi gear lockout which gives you the ability to lock out whatever gears you like.
http://www.dynotunenitrous.com/store...?idproduct=194
Dean
Old Oct 27, 2006 | 05:12 PM
Todd157k's Avatar
I have the Mallory from Nitrous Direct. Works great and NO PILLS. Up/Down arrows set it up.
