Newbie needs HELP!! What system to run??
Old Oct 29, 2006 | 12:42 PM
Brad02Z06's Avatar
Default Newbie needs HELP!! What system to run??
I have a 02 Z06 w/ MS3 , kooks longtubes, off road x-pipe, halltech cold air and soon Vengenace ported FAST 90 w LS2 TB. I want to spray 150 shot. What kit do I need to go with wet or dry. Is there a kit that you can get everything you need windoe switch, heater, purge , etc...
Thanks
Brad Morring
Old Oct 29, 2006 | 05:07 PM
sprydncamd ta's Avatar
check out harris speed works kits they have some nice stuff and their brute force series is customizable heres a link to their wet kits if you go dry you will have to see what duty cycle your injectors are at because you might have to upgrade them
http://www.harrisspeedworks.com/shop/home.php?cat=301
Old Oct 29, 2006 | 05:48 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
Our wet kit performs very well on the ZO6. Check out the video of our wet kit in an 03 ZO6 - $359 for the most complete kit on the market you cant go wrong. Not to mention at the tops in performance.
http://www.dynotunenitrous.com/store...ideo_150hp.wmv
http://www.dynotunenitrous.com/store...?idproduct=115
A window switch would run $129 and includes options for 2 stages if you go that route down the road, built in TPS so no need for a wide open throttle switch offering a cleaner install and multi gear lockout so you decide what gears you want the nitrous in. We offer the top heater on the market for $99 complete. Complete purge kit would run an additional $59.
Hope this helps!
Dean
Old Oct 30, 2006 | 11:23 AM
Robert56's Avatar
Thanks
Brad Morring
We sell by far more PRO Dry kits for the Z06/C5 than any other. Kit has everything for a complete install, dual SS nozzles, 400hp mondo PRO noid, NHRA Blow down, FPSS, Bottle Gauge. I am currently running a 250rwhp dual stage dry on my bone stock ls6. Check time in sig, and see the Ultimate PRO Dry thread.
Nitrous Direct PRO Dry and PRO Wet kits
Now if ya want to go wet, then the cleanest looking kit has to be the MAF Kit, check it out.
Nitrous Direct/NX MAF kit
The we have the plate kit for the 90mm set-up,
Nitrous Direct/CF Plate Kit
Here's the PRO Pack II from CF, we also have the GEN X kit (similar to the CF kit) from NX.
PRO Pack II
We have many controllers to choose from, and bottle heater kits which are not included in any kit. If you have any concerns or questions give me a pm.
Robert
