Nitrous being lugged
Old Nov 2, 2006 | 04:10 PM
MEAN LT1's Avatar
Default Nitrous being lugged
I have a 3.23 geared m6 with a tnt f2 system. What I wanted to know is will adding in some 100 octain and jetting it a little rich help prevent detonation?. The reason Im asking is consider the situation. I have m6 with 3.23's will probably be running a 100+150 shot.
What Im worried about is the load on the motor with the gears I have and spraying out of the hole. Or should I just wait to hit it in second gear?.
Old Nov 3, 2006 | 05:44 PM
MEAN LT1's Avatar
Am I to assume no one understands my question?
Old Nov 3, 2006 | 06:19 PM
srsnow's Avatar
If your question is if you can use it in first gear, than yes you can.
Old Nov 3, 2006 | 06:22 PM
MEAN LT1's Avatar
I understand I can use it in first gear but will the load of of the 3.23's and a sticky track make the motor prone to detonation?
Old Nov 3, 2006 | 07:36 PM
srsnow's Avatar
It really depends on how well the engine can move air. If you are trying to launch just off idle than yeah probably not a good idea, if you are going to bring the rpm up so that it doesn't bog then there will be no problem. I honestly don't think you will have that much of a problem but if you are worried you could always get something like a digiset and set it up for like a 1/2 second delay to give the engine a chance to get some RPM.
Old Nov 4, 2006 | 08:39 AM
MEAN LT1's Avatar
Thanks man.
