Plate system
Old Nov 6, 2006 | 05:32 PM
02blackbeauty19's Avatar
Default Plate system
I have a normal cold fusion wet kit and am wondering what it takes to make it fit on of those plate kits. What all do i need because i think the plate it a nice look. And if i just need the plate, where can i get it? Thanks all
Old Nov 6, 2006 | 08:44 PM
Demon_Speeding's Avatar
Nitro Dave could hook you up with a plate. All you'd really have to do is remove the lines/jets from the nozzle, remove the hole the nozzle was in. Then install the plate behind the TB, install the jets and run the lines to it. That'd be about it. Do a search for "plate" and you should come up with some results. I haven't heard one bad thing about it.
Old Nov 6, 2006 | 09:06 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Yes, all you need is our plate conversion. It supplies everything you need to run our plate on your vehicle. Let me know what vehicle and TB size and I can get you the correct part # and pricing
Old Nov 6, 2006 | 09:57 PM
Thanks Ray, ill shoot you a pm
