tps wire question
Old Nov 11, 2006 | 02:54 PM
99WS7's Avatar
Default tps wire question
ok, from searching around I found that the dark blue wire is the TPS wire. Just to make sure I turned my car on and used a volt meter to see if anything would change when I moved the TB blade and it did nothing. Infact it seemed to be reading a steady 11-12 volts like from the batt, does this make sense. I just wnated to make sure I was taping into the correct wire for my n20 install. Im going to use the tps for my WOT. Thanks for any help.
Old Nov 11, 2006 | 02:59 PM
S99TA's Avatar
use your volt meter ground the black lead probe the back of the connector with the red lead on all the wires w/ the key on till you find the one with about half a volt .50 or more
Old Nov 11, 2006 | 04:18 PM
99WS7's Avatar
so your saying its not the dk blud wire. I check the others.
Old Nov 11, 2006 | 07:38 PM
oange ss's Avatar
it is the dk blue wire and PIN 22 on the PCM
