Nitrous help PLEASE
Old Nov 17, 2006 | 08:57 PM
02blackbeauty19's Avatar
Default Nitrous help PLEASE
I Have my nitrous system hooked/wired up and all i need is to find my tach wire to tie my window switch wire into and im not sure which one it is. Its a 2002 Corvette. Any help would be appreciated Thanks
Chris
Old Nov 18, 2006 | 01:18 AM
Robert56's Avatar
Pull the inner fender liner on pass side, then under batt area is the pcm. You'll see two connectors a red and a blue. You want the #10 white wire on one connector. Only one will have a number 10 and a white wire, that's the tach out put. Use a red wire crimp connector, the kind you use pliers to close and run new wire up behind battery.
Robert
Old Nov 18, 2006 | 09:16 AM
Thanks Robert !! You have been a big help. I really appreciate it.
Chris
