No TPS??
Are you sure you have the right wire plug on the throttle body?
There are two set's of wire's coming out of it.
The correct plug is the lower one.
Fish out the dark blue one and run a continuity check from that wire to pin 24.
If it reads zero your good.
Stupid question, but did you press the pedal all the way to the floor when you were trying to get a reading?
