Tnt F2
Old Nov 26, 2006 | 07:23 AM
ELMiN8oR's Avatar
Default Tnt F2
before i buy the kit any body have a TNT F2 100 shots pictures or maybe some tips for the best way to install the kit without having any problems that can effect the engine. if you recomend something please post some pictures.
Old Nov 26, 2006 | 08:51 AM
sprydncamd ta's Avatar
i highly recomend this kit click twice for big pics
http://www.harrisspeedworks.com/gall...s.php?album=34
hsw brute force kit
Old Nov 26, 2006 | 09:10 AM
99WS7's Avatar
those are some bad *** pics!
Old Nov 26, 2006 | 10:17 AM
ELMiN8oR's Avatar
awsome kit.
i'm really thinking of TNT 100 shots as a good start if you recomend this kit i will check it out.
Old Nov 26, 2006 | 03:14 PM
BuBbABFP's Avatar
Ive got the tnt kit.. its super easy to mount on your TB section, the kit comes with excellent instructions that even have the ls1 motor printed on thyre, just fallow them step by step.
Old Nov 26, 2006 | 04:18 PM
9secondz28's Avatar
i think its the best kit on the market makes true power! and is very easy to set up im selling a lt1 kit now F2 cheap you can buy the kit and all you need to get from tnt would be the ring save a few hundred$$$ email me tt9secondz28@hotmail.com or 9secondz28@bellsouth.net heres the ebay auction # 320054454934 check it out thanks...
Old Nov 27, 2006 | 02:55 AM
ELMiN8oR's Avatar
do you have any idea about "window switch"cause i really new to nitrous so can you explain what it is cause i'm seeing people using it cause i'm a guy who knows nitrous only by pushing a button to spray the engine.
i'm going to buy a new kit.
Thanx for the offer
Old Nov 27, 2006 | 03:23 PM
9secondz28's Avatar
well you can get a wot window switch that kicks the spray on when your at full throttle which i have used many times in single or dual stages still haveing to arm from a switch but best thing about it is that if anything goes wrong with the run last thing to have to think about while listening and lifting off the gas is turning off the n2o if your out of wot its off or if your at the end of the track just let off the gas to slow down and it disarms its self just turn off the switch when you get to return road you can use a micro switch or tnt and nos zex they all make a tps switch now thats nice just have to wire it up cleaner install in my books theres soo many on the market use the wot switch for your second stage and a button for your first launching stage how ever you want..
Old Nov 29, 2006 | 02:42 AM
ELMiN8oR's Avatar
which wot switch do you recomend ??
Old Nov 29, 2006 | 02:41 PM
Reject's Avatar
http://www.dynotunenitrous.com/store...?idproduct=194 DYNOTUNE FTW!!
that'll take care of the window switch, gear lock out, and the micro switch.....pretty sweet huh!
Old Nov 29, 2006 | 02:46 PM
ls1CANTU's Avatar
You Can't Go Wrong With The Tnt It's An Awesome Kit And Nice Clean Install.
Old Nov 30, 2006 | 05:17 AM
ELMiN8oR's Avatar
yes i can see that most users in this forum use TNT kit, and i can say that this kit amazes me with the amount of power that people get. thats why i'm thinking of TNT not any other product
Originally Posted by reject
http://www.dynotunenitrous.com/stor...p?idproduct=194 DYNOTUNE FTW!!
hsw brute force kit
thanx for the link it was really useful. so this device is the Window swtich, gear lock out, and the micro in one ?
Old Nov 30, 2006 | 10:24 AM
TRMIN8R's Avatar
TNT FTW!!!! Good luck with the install!
Old Nov 30, 2006 | 08:49 PM
BuBbABFP's Avatar
The dynotune is the one i use, It comes with TPS(you wire to your TPS wire in your TB, no need for Micro/WOTswitch) It sprayes by using the volts your TB uses while WOT, it has a a built in Window switch, and multi gear lock out witch is a very nice option when running a stock 10 bolt. You can lockout 1st gear.
