help with tnt 90 f1 kit
Old Nov 26, 2006 | 11:12 AM
shkettle's Avatar
Default help with tnt 90 f1 kit
i put the ring on it is loose as can be. anyone have ne suggestions on what to do. i have the nick williams 90 throttle body. i dont want a vacuum leak after the air mass. plz message asap-the car is torn apart and i got to drive it to work tommarow.
Old Nov 26, 2006 | 08:57 PM
JoeyGC5's Avatar
Find an original ring, or try to build the throttle ring base up with electrical tape maybe??
Old Nov 27, 2006 | 11:33 AM
David@TNT's Avatar
Well you really need to define loose in more specific terms so we can come up with a solution, we can go back in forth on the topic on here or just call (903-839-5498) and I will get ya fixed up, thanks David@TNT..
Old Nov 27, 2006 | 02:01 PM
JoeyAnderson's Avatar
Give David a call - he offers GREAT customer service and is sure to help you out.
The outer opening on the NW TB is very close to the opening on the STOCK throttle body. The 90mm TNT ring was designed using the FAST 90mm throttle body, which is significantly larger.
Old Nov 28, 2006 | 02:47 PM
David@TNT's Avatar
Ya what you said man!!! Your so getting a discount next time you order.. But on the power ring side we offer 3 rings for the ls1... 1. For the stock LS1 tb, 2. 90mm for the stock LS2, 3. FAST 90mm ring.. Now since there are so many different tbs out there we have to go off the most consistant castings and most popular, but we do have the ability to cutom turn rings for just about anything out there so no fear, TNT is here lol.. David@TNT
Old Nov 28, 2006 | 08:25 PM
shkettle's Avatar
i called tnt and the ring i got was wrong. they are sending me out a new one that should be here this week.
Old Nov 29, 2006 | 01:43 PM
David@TNT's Avatar
Sorry for the mix up man, but we do what we can to make it better.. David@TNT
