Warning!!!!! : Manufacturers recomended jetting
Old Nov 27, 2006 | 02:04 PM
SmaknaSS's Avatar
Originally Posted by 383LQ4SS
In response to the other thread about the blown motor...and a few other recent stories I have heard....manufacturers recomeneded jetting is just that. A recomendation for a starting point to get you close on Af ratio for a certain size shot.
You guys have to keep in mind that these are just starting points. IMO it is still up to the end user to get on a dyno with a wideband...or use an onboard wideband to check the ACTUAL AF ratio. Many many times you will find tweaking the actual jets will be required. If nitrous manufacturers could control all possible variables they would state with a certainty to use a specific jet under all curcumstances. But there is too many things that can change to have an affect on a combo. So IMO its rule of thumb to check your ACTUAL AF ratio after every install..AS WELL AS regular intervals from time to time....or when you feel its not running right.
IMO this goes for a 50 shot on up. Just dont take the chance. Yes...9 times out of ten youll get away without checking....but who wants to be that tenth guy?
Most here know that..I just wanted to reiterate this point for some of our newer lurkers.
Ain't that the truth! I was given a Jetting sheet for a dual nozzle kit of:
HP N20 Fuel@10PSI
35 - 31 - 24
50 - 35 - 26
75 - 41 - 28*
I ended up needing 18.5 PSI of fuel to get the right AFR of around 11.5-11.8 .
Old Jun 2, 2007 | 08:45 PM
383LQ4SS's Avatar
just a TTT for exposure...some people made some great points in this thread and want to reiterate.
Old Jun 11, 2007 | 03:09 AM
BayAreaSS's Avatar
This is a good thread.
So when i'm done with my install and ready for a tune....what extra jets are needed?
Do i need nitrous and fuel jets? or just fuel?
Old Jun 11, 2007 | 12:02 PM
383LQ4SS's Avatar
You likley wont need any extra jets. Once you determine your AF ratio...let that guide you. And many times youll have the jets required in the kit.
Old Jun 11, 2007 | 12:22 PM
BayAreaSS's Avatar
Ok thats good to know.
My plate came with 50-200 jets.
Thanks a lot
Old Jun 11, 2007 | 01:29 PM
tunedbytad's Avatar
I ended up needing 18.5 PSI of fuel to get the right AFR of around 11.5-11.8 . // H/C and Nitrous. 408 and a big DP shot in the plans.
Really....
408ci div by 346 =s 1.179 difference in size and most likey power output
you will need 18% more fuel to make 18% more power
