Trick Window switch and Timing Tuner used together???
Old Nov 29, 2006 | 02:04 PM
kazfan30's Avatar
Default Trick Window switch and Timing Tuner used together???
Well i already have one of Nitro Daves Trick Window switches and needed a way to pull timing out during N2O....I love the trick switches "gear lock-out and TPS activation features and want to use it and the Timing Tuner as well..............anyone ever used both at once or know how the wiring would be.......just plug it in like intended or splicing required
Old Nov 29, 2006 | 06:33 PM
jwarren's Avatar
That is how I have my system setup.
Here is the wiring diagram I used, I think it was originally posted by NXRICKY
Basicily you don't hook the grey wire for the timing tuner up at all, just the white on the 12v (armed portion)
Attached Thumbnails Trick Window switch and Timing Tuner used together???-timmingtunner-mod.jpg
Old Nov 30, 2006 | 08:15 AM
kazfan30's Avatar
thanks man, ill try to use this and see how it works out....
