First 8 second n20 pass
8.917 @ 152.4
Not to shabby considering i drove it home
I love this new nitrous kit.
Ill post the vid up soon. Mods if this needs to be moved go ahead
Yes and he has LT1 edit also
I guess your being a little tight lipped about your combo?
What kit are you using, your sig said hydro roller,really?? Then that would make it below 7g motor.
Not tight lipped except for a few guys Pm me and ill run it down if you want. noi secrete on the kit its a wilson pro flow 2 stage plate. very nice kit but requires removal of the cowl in the centerif you put a top mount tb on it.
the complete long block was around 6K ut i already owned an iron block and a callies crank. so 7-8 would probably be close. Eric @ HKE built it and would know more about the internalls than I . It was built for the 600 shot(what we thought we needed for 8.50) but we have only hit it with 225 full pass and 150 for the top 1K rpm. tracks closed around here so it will have to wait till spring.
oh yeah feel free to call jeff at psi he helped me spec everything out and tunes it. he can build you a copy if you want
