how much fuel psi?
Old Dec 6, 2006 | 04:24 PM
s10_ls1's Avatar
Default how much fuel psi?
i am getting down to the final things to get and my swap is done i have been thinkin about goin ahead and putting a seperate fuel system in for the nitrous how much psi of fuel would i need to run in the nitrous fuel system...thanks
Old Dec 6, 2006 | 06:36 PM
Phlip00WS6's Avatar
between 40-60 would be good.
Old Dec 6, 2006 | 10:32 PM
s10_ls1's Avatar
thanks for the help really appreciate it
Old Dec 7, 2006 | 06:20 AM
cjg454ss's Avatar
you could do low pressure. 6-7 psi
Old Dec 7, 2006 | 09:16 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
just for an example...our dedicated fuel systems will support 900hp set for high pressure, and 1200hp in low pressure. If you stay with high pressure your current jetting will work, if you switch to low pressure you will need to change the jetting to compensate.
I would reccomend staying with the same fuel pressure as your car is running, unless you need the extra head room on the pump you are going to use.
Old Dec 7, 2006 | 11:53 AM
s10_ls1's Avatar
thanks alot guys and i heard u can run low psi with differnet jets and stuff i rather just run the high so it can be set the same as the truck and go from there again thanks and i really apreciate it.
