Nitrous Question
Old Dec 7, 2006 | 11:07 PM
2FastSS2000's Avatar
Default Nitrous Question
I've heard that when you put Nitrous on, you will need to buy a stronger rear end. Any help would be much appreciated.
Old Dec 7, 2006 | 11:25 PM
sweetness's Avatar
as with any major power adder rearends are an issue more so with manuals than auto's although if you were planning on dragging this thing and you are worried about your rearend you could always not choose to spray out of the hole and just have a progressive controller
Old Dec 8, 2006 | 12:34 AM
00formLs1's Avatar
it depends if you spray off the line. there are window switches that have fetaures like first gear lock out. with a window switch you can have the nitrous turn on at 3000 and off at 5900 for the shift.
a progressive control will start the n2o at a certain percentage and have it go to 100%.
