238/242 on116 safe to spray 150
Old Dec 13, 2006 | 09:52 PM
formu8's Avatar
Question 238/242 on116 safe to spray 150
is it safe to spray a 150 shot on this cam with all the safteys?
HSW Wet shot
ffps
Purge
HSW Heater
Dyno tune a/f gage reading of the oxgen sensor
BMN window switch
A/F ratio switch
Is there any other products I need to purchase?
thanks
Old Dec 13, 2006 | 10:15 PM
formu8's Avatar
it is a98 Formula with stock heads and all the bolt-ons
pt Body
ls6 intake
tts long tubes
3"Magna flow ehaust
Custome tune from RPM
anybody?????
Old Dec 13, 2006 | 10:32 PM
formu8's Avatar
Lightbulb
I have been told that this to large of a cam to spray!!!
is that true?
I already have the kit
and the stuff I have listed to go along with it!
sorry a newbie to the spray!
Old Dec 14, 2006 | 04:00 PM
ls1-ss's Avatar
I would say that cam is fine for a 150 shot. Look at all the cars out there that are using nitrous with a trex and ms3 and those cams are bigger than yours. With the 116 lsa I don't think it will be a problem. Call some respectable speed shops and get their opinion, theres plenty of them in texas.
Old Dec 14, 2006 | 04:55 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
you might want to check on an upgraded fuel pump....my guess is you will be pushing 5-550rwhp on a 150 shot....that is alot to ask of a stock pump
As far as the cam being too big...???? not sure where that is coming from...I am running a 246/254 .613/.590 112 in a LT1, going to hit it with 250-300
Old Dec 16, 2006 | 09:47 PM
formu8's Avatar
Thanks for all the info....
I am upgrading the fuel pump to the 225 wlb.
and the injectors to 42's.
that should be safe for this set up from what I have read!
Thanks, for the advise....they had me scared with the cam I have
happy spraying!!!
