New to nitrous with 685 questions.
1) What should I set the main rev limiter at? What is the factory limiter set at?
2) Being extra cautious, what should I set my window switch at? Opening RPM and Closing RPM.
3) What is the best way to hook up the timing retard function? How many degrees should I retard the timing with my PCM performance tune?
Any other advice would be appreciated as well.
You should set it for 200-400rpms BEFORE your shift point/rev limiter, whichever is lower.
No earlier than 3000rpms for opening, and close mentioned piror.
What size shot? If its 100 or less you dont need retard unless your tune is on the NA Edge. If you dont know what your tuning is, you could get ahold of PCM4ess and see if they can get that info. Then, report back we can go from there. Also, R.O.T. is 2* per 50 shot, that's just a rule of thumb though.
Correct me if I am wrong but I think the factory rev limiter is set at 5800.
Open RPM should never be below 3000rpm, that is to ensure you have enough velocity through the intake to prevent puddling.
Close rpm should be 1-300rpm before the rev limiter on a M6 or befoere the shift point if an auto and you do not want to spray through the shift.
Spraying through the shift will net a faster ET but will be harder on the tranny.
For my personal car my window is 3000-6900 w/a 7000rpm rev limiter
My current shift point is 6500 w/a full manual 700r4.
I am spraying from green light to win light.
Hope this helps...let me know if you have any other questions.
P.S. try to keep a straight face the first time you spray it....I didn't stop smiling for a week
The timing retard question was mainly directed towards wiring. Where does the yellow wire coming out of the 685 connect to? All it says in the instructions is that 12 volts activates. I looked for a wiring sticky with that info and came up with nothing. Does anybody know of a wiring diagram for a Wet kit/Mallory 685/FPSS/Purge ??
I guess what would make my questions a little more clear is this: If this were your car, how would you set the 685 settings?
Main RPM limiter: 5800 RPM's
Window Switch Start: 3200 RPM's
Window Switch Finish: 5600 RPM's
Timing retard when Nitrous is active: 4 Degrees
Since I have the PCMforless tuning, I figure this would put me at about 2 degrees retarded. (Counting the advance of the tune)
If I ever disconnect my battery, will the 685 keep my settings stored or will I have to reset them every time?
