Will this do it?
HSW LT1 Wet Kit
HSW Advantage Progressive Nitrous Controller (I will be traction limited on street tires lol.)
Ashtray Switch Plate
NGK tr-6's
FPSS
Mallory 685
I will run a 125 shot...so how much timing would need to be pulled 4-5*
Any other suggestions or anything else to make it safer?
If you have any other questions let me know.
Thanks,
Matt
HSW LT1 Wet Kit
NGK tr-6's
FPSS
Mallory 685
Well the car will have full exhaust and CAI along with a tune from a local tuner. So I'm not sure how much or if the timing will be advanced or not, I will find out for sure though.
I have a question though...with the Mallory 685 and progressive controller, If I set the window switch on the 685 at say...3200-5800 and have the progressive controller set to like 50% start, 100% finish the spray wont come in until 3200 right? I mean the progressive controller wont spray 50% off the line or will it? I just dont know if there is any reason to get both, would traction be that limited at 3200 rpm's?
If it's a street car that goes from a dig a progressive controller will help a lot. If it's a track car with slicks and suspension dialed in you may be able to hook right up, depending on track prep.
Let me know if you have any other questions.
Thanks,
Matt
Thanks Again
Matt
Thanks Again
