Has anyone seen one of these heaters?
http://www.gotsqueeze.com/
It says they were at PRI, anyone see it?
Its 60Watts, I'd like to see a heat time graph for this one.
if thats the case, then the ZEX bottle heater wouldnt be around. that one is based on the temp of the bottle
I can dig it.....but I would still rather have one that turns on/off because of the bottle pressure, not temperature. But like they said...regular heaters cant COOL a bottle. However...in my experiance with peltier plate cooling...its gonna take FOREVER if your pressure is at say...1200 psi on a hot day for that thing to cool a full bottle down to 950. But in fairness I have not seen this one work. it is well insulated...but its kind of a monstrosity of a unit.
So yes, it's bulky, kind of an ugly green, and takes a while to heat or cool a bottle. What we set out to design was a temp/pressure control system - and not necessarily a bottle "heater". The the true value of the system is that you can put you bottle in it and it will keep it at whatever temp/pressure you set it at - and it will keep it there indefinitely - while only drawing 5 amps. The other important point to note is that it will both heat OR cool the bottle to do this. If you like to run your system at 950 psi, then set it to 86 degrees. If you run more or less pressure, then you adjust the temp up or down accordingly. It's all easily done from the control panel with a digital readout.
If you need to put heat in a bottle quickly, we still recommend a blanket heater. If you need to cool a bottle down in a hurry, purge it. But if you are concerned about a consistent nitrous tune up, and need your bottle to get to, and stay at a constant temp/pressure, then we have a pretty good solution for you - and it's easy on the electrical system.
Having said all that, we have listened to all the feedback and now have systems in multiple colors - red, blue and yellow for now. We are also considering custom colors for an added cost.
We are also developing a 15lb version that will be leaner (though taller) than it's current 10lb brother. If all goes well, this new 15lb version will accommodate both a 15lb or 10lb bottle.
There's so much more I could say but then I'd be bogging down your forum and sounding like a used car salesman. Please let me know if you guys have any questions or other feedback.
Thank You for the interest.
Dennis Clark, Jr.
Carnivore Performance
www.gotsqueeze.com
866-405-8795
as for mounting, our system has 4 embedded, threaded brass inserts in the back that have been pull-tested to 1000 pounds.
Thanks, Dennis
