MSD window, nx wot/tps switch question.
Thanks
However as I think about it, this reminds me of the recent thread where the guy wanted to wait to flip the activation switch until he was at WOT and in window range to spray immediately on turn-on - and the solenoids wouldn't open. I thought the problem might be that the window switch has to be powered up in the disengaged state first as a fail safe, and won't activate immediately on power-up. Which would be the case if the range was set to 0 rpms and the ignition turned on (without running).
I say try jumpering the window switch first, see if that gets the noids to click.
this will cancel/bypass the set rpm window(s)
its how i test fire when mocking diff things up.
works great.
FWIW
