F/S: Nitro Dave's fuel system *cheap*
Old Jan 8, 2007 | 09:51 AM
fastenough's Avatar
Default F/S: Nitro Dave's fuel system *cheap*
I have decided to stay with pump gas for my setup and run a slightly smaller shot, so I am putting this up for sale. It has NEVER been used, I just opened the box to check things out.
http://www.nitrousoutlet.com/catalog...product_id=927
Fuel system comes complete with a 1 gallon fuel cell, Walbro intank fuel pump, Areomotive fuel regulater, Aeroquip -6 hose, lines, and fittings.
System is designed to flow high or low pressure by changing a spring in the fuel regulator.
The stock battery hold down clamps fasten this unit in. So there is no drilling on the car required. Battery relocation is required to use this system.
This system comes setup for 1 fuel solenoid. If your application has 2 fuel solenoids you will you need to purchase the needed upgrade.
$600 + shipping.
I am open to reasonable offers.
Old Jan 8, 2007 | 10:00 AM
Frost's Avatar
You copied a truncated link
But it doesn't matter; it'll get the here soon.
Old Jan 8, 2007 | 10:04 AM
fastenough's Avatar
Oddly enough...I've seen other people get away with posting this stuff here. Link is fixed.
Old Jan 8, 2007 | 12:16 PM
383LQ4SS's Avatar
Good deal there! Im sure someone will ****** it up soon! I have used the Nitros Dave tanks and they are top notch.
Old Jan 8, 2007 | 03:43 PM
CRAGER's Avatar
Administrator
This is NOT the For Sale section.
Please post in the correct sections.
Thanks,
Craig.
LS1TECH.com
