Stock Fuel pump?
Old Jan 16, 2007 | 03:34 PM
ArrestMeRed99Z28's Avatar
Default Stock Fuel pump?
I am a newby to nitrous so please go easy on me. Search didn't work and I read the stickies. I only have a couple of basic bolt ons, headers, cat back, lid. Can I spray a 125 shot on my stock fuel pump? I'd only want to spray a 75 or 100 shot, I'm happy to go 12s. But if I wanted to turn up the wick, could I?
Thanks in advance
AJ
Old Jan 16, 2007 | 03:37 PM
NitrousDirect's Avatar
you should be good up to about 125, if u want to play it safe sit around 100, 125 is ok but pushes it and 150 can even be done but you'd have to get a/f stats and it would be iffy.
Also pull 2 degrees of timing if you can at 100hp and 2 degrees for every 50 over that
Old Jan 16, 2007 | 09:34 PM
thanks very much. Would I be safe at a 150 shot if I were to use a FPSS?
Thanks
AJ
Old Jan 16, 2007 | 10:46 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
A fuel pressure saftey switch and a window switch are 2 things that will help any kit.
But it all comes back to the fuel pump...the Racetronix is only $249 and is more than worth the peace of mind.
