FFHP SHORTBLOCK 408 ??? on NOS
Old Jan 16, 2007 | 08:28 PM
GONEB4U's Avatar
Default FFHP SHORTBLOCK 408 ??? on NOS
I was one of the so called lucky ones who actually received their 408 shortblock from FFHP before they went under. I checked out everything on it today because I'm thinking about putting it together. What I have found is that it has a Eagle crank 4.00 stroke, Compstar 6.125 rods and Coated top Diamond -2cc flat top pistrons. What I found seems to me a little out of the norm. The piston is out of the hole on tdc by .025. I plan on running a Cometic head gasket with a compressed thickness of .055 and I'am looking to run 250+ HP of nitrous through it. I do not like the tight quench of .30 on the bottle. I spoke to Diamond today who gave me 2 suggestions. 1. Mill .015-.020 off the top of the piston and loose the coating. or 2. Go to a .074 Cometic head gasket. What would you do if you were in my shoes?
Old Jan 16, 2007 | 08:56 PM
383LQ4SS's Avatar
Go with the thicker gasket IMO. Nothing wrong with a .074 Cometic.
Old Jan 17, 2007 | 11:38 AM
LostCauseZ06's Avatar
the thicker gasket will probably give you a higher chance of blown head gaskets... but cometics are pretty kick ***..
id rather have a thicker gasket and keep the coating on the pistons if it was my engine.
Old Jan 17, 2007 | 01:21 PM
koolrayz's Avatar
isnt .050 high on the quench? wouldnt you want around .040?
Need to ask this in the internal section IMHO
Old Jan 17, 2007 | 03:34 PM
that quench is a little too high... you want your quench around .042 - .045 if i remember correctly
Old Jan 18, 2007 | 08:58 PM
GONEB4U's Avatar
I ordered a .074 Cometic head gasket for that added safety measure.
