What Should I Do?
Old Jan 18, 2007 | 06:26 PM
ROLLN's Avatar
Default What Should I Do?
i have the nos 5177 kit, it just seems like i am not getting enough of out my run. i wasnt really looking to upgrade to a wet kit. i am runnin 032 jets. what can i do to get more out of my kit. i was thinking about doing a plate or something because i am currently runnning mine through my airbox, what do you guys think i should do to get more out of my kit? any help is appreciated.
Old Jan 18, 2007 | 06:52 PM
juicedls1's Avatar
If ur going to keep ur dry kit then the nozzel placement has got to be before the MAF, now if u wanted to run a wet kit then u could do the plate setup like mine or nozzles after the MAF, for a little bit of info when i switched to my plate setup i picked up 4 tenths and 6 mph through the 1000ft, the wet felt so much stronger but there is going to be people on here telling u different so just go with ur instinct... then again u could go with bigger injectors, pump and a good tune and up ur jet size! On my 5177 kit i ran .046 jets on the stock fuel system and didnt mess anything up, guess i was lucky!!!
Old Jan 18, 2007 | 07:19 PM
ROLLN's Avatar
who has a good nozzle placement system that you would recconmend and also what wet shot upgrade would you reccomend. thanks again for your help!
Old Jan 18, 2007 | 07:21 PM
ROLLN's Avatar
and if you could explain how the jet numbers and horsepower ratings work for a dry kit like the 5177 lit i would really appreciate it.
Old Jan 18, 2007 | 11:03 PM
Robert56's Avatar
The .032's are about 85rwhp shot, but they rate them as 100hp at crank. This is one of the biggest problems with the 5177, the way they rate it. It will seem as though it's a dog. Also, the stock nozzle location will cause a slow progressive hit. Check out the wet vs dry thread for insight on good nozzle placement, look for the dyno graphs showing what nozzle style and location can do. If you still have questions let me know, I will help. If set-up correctly, your dry will hit and perform just like any wet hit/kit.
Robert
