DynoTune 2 Stage Window/TPS switch questions
I do have two quick questions however.
1) The Dynotune window switch has RPM range settings for two channels. I am assuming that there are two channels for two stages of nitrous. If that is correct do I just enter values for the first channel (because I only have one stage of nitrous) and then enter values of zero for the second channel's RPM range?
2) Also should the window switch show a value of 0.L.0 after I am finished programming it? It did say "END" first, but now it just shows 0.L.0.
THANKS.
the 0 L 0 means
fisrt digit is tps. 0 = not at full throttle
2nd digit is 2nd stage L = lockout is on
3rd didgit is 3rd stage 0 = not in the set rpm range.
So at WOT if the TPS is set correctly that will switch to a 1. The L will change to a 0 or 1 once you pass your lock out setting. you will see a 0 if you are not in the window, and a 1 if you are in the window.
The 3rd digit will also change to those numbers but does not matter seeing how they are not hooked up.
