TPS wire and Tach wire HELP
Old Jan 26, 2007 | 12:59 PM
Sluggish's Avatar
Default TPS wire and Tach wire HELP
im trying to install my tps/window switch........the wires i hook it up to are on the computer right.....it says green coming out of the box is the tach and the blue is the tps......are they the same color on the computer.....i saw one sold green wire........but 3 solid blue ones...........which one do i hook up to
Old Jan 26, 2007 | 01:05 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
No the colors at the computer are different. I do not know the pin numbers at the pcm. But for tach there is a green wire on the passenger side coil pack plug, and then on the TPS there is a blue wire there,
Hope this helps.
Old Jan 26, 2007 | 01:16 PM
Sluggish's Avatar
is this what you are talking about
Old Jan 26, 2007 | 01:23 PM
NXRICKY's Avatar
Yeppers green wire white stripe is #6 coil trigger.
Ricky
Old Jan 26, 2007 | 01:26 PM
Sluggish's Avatar
also if i come off 86 goto the switch then from the power side of switch to the box is that right............for arming the system
Old Jan 26, 2007 | 01:31 PM
NXRICKY's Avatar
You toggle switch sends power to the relay and to that box. The toggle switch gets its power from a fused source.
The large black dots are just showing connentions.
Old Jan 26, 2007 | 01:33 PM
Sluggish's Avatar
ok thanks.......i was thinking of it going backwards................i hate wiring......its my own personal hell
Old Feb 15, 2007 | 07:48 PM
cjg454ss's Avatar
i tried this and tapped it above the plug and i cant get a signal. should i go below the plug?
