Nitro Dave's Dedicated Fuel System
Old Feb 16, 2007 | 09:36 AM
  #41
Nitro Dave's Nitrous Outlet's Avatar
Wyndzer,
Install looks great. Thanks for sharing it. Your dedicated should have came with to push in style tabs to attach to the fan shroud. Ill get you added into the customer section. Can you send me this info. http://www.nitrousoutlet.com/customerCars/help.asp
Hugger427- Ill get Courtnay to add it in. Can you send me this info. http://www.nitrousoutlet.com/customerCars/help.asp
Thanks guys.
Dave
Old Feb 17, 2007 | 04:52 PM
  #42
408zo6's Avatar
i will send a pic of my set up win its done thanks chris for all the help
Old Feb 20, 2007 | 10:27 AM
  #43
GrimReaper's Avatar
Thanks again for all the pics, it really helped me out. I got it started last night and will post pics up when it is finished.
Old Feb 20, 2007 | 07:55 PM
  #44
smokeum99ta's Avatar
I bought one of the fuse style setup's last summer. It's an awesome piece but there were a few things I didn't like about it( I'm not busting anybodies *****). First I didn't like the way it gets mounted, I thought that it should use one (or two) of the factory bolt holes next to the light or get a slight notch or something on the mounting plate to avoid the headlight bolt. Last I changed the fitting coming out of the tank (return line) into a one with a built in 90 so the hose would haven't have such a sharp bend in it, it just made it look alot better.
Old May 12, 2007 | 10:07 AM
  #45
myfast70's Avatar
Any pics?
Old May 12, 2007 | 01:12 PM
  #46
TRMIN8R's Avatar
Originally Posted by hugger427
Dave...
Why did you show that pic with the DP system we had to throw away (not Dave's)? Take a peak at these pics that show's off Dave's DP system too. Again, you get what you pay for and Dave takes care of his customers!!!
http://good-times.webshots.com/photo...43971568nCtwaF
http://good-times.webshots.com/photo...43971568bftrir
Your engine bay looks ****** badass!!!!!
