15v not good for noids?
Old Feb 11, 2007 | 09:08 AM
bayer-z28's Avatar
Default 15v not good for noids?
I have the WOT V+ booster. I really don't think it does much. I'm gonna dyno the difference eventually.
anywya... I take it the noids can't handle 15v? It'll fry the windings?
Old Feb 11, 2007 | 11:01 AM
NEVR2ND's Avatar
The noids will be OK.
Old Feb 13, 2007 | 08:37 AM
nate-roth's Avatar
I have that system too. Ever notice how the headlights get a lot brighter when the volt blaster comes on. I'm just now putting together my new N20 kit, so far in testing the noids have operated normally. The volt blaster probably won't increase hp, but will help the fuel pump and ignition system deal with the demands of the spray.
Old Feb 13, 2007 | 11:34 AM
srsnow's Avatar
The solenoids should be fine. Guys use the same solenoids on 18v systems with out too many problems. They will generate heat faster and open to a higher pressure than normal but other than that there shouldn't be any real problems.
Old Feb 14, 2007 | 09:06 PM
mrdragster1970's Avatar
6 & 8 Second Club
I sure hope not, been using 16V on fast car since it was built, it's 12 years old.
