which window switch should i get??
Old Feb 11, 2007 | 02:43 PM
LT194CamaroZ's Avatar
Default which window switch should i get??
i was wondering which window switch i should get,i saw the MSD one is pretty cheap, is a window switch just a window switch or are there some better ones out there,sorry about the dumb questions but i'm new to this stuff and trying to make it safe
Old Feb 11, 2007 | 07:10 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
We use to carry the MSD but no longer do - this unit blows it away!
http://www.dynotunenitrous.com/store...?idproduct=194
This 2 channel RPM activated window switch (RPMWS) also has an integrated throttle-position activation switch (TPAS)!
It also has a feature called "Multi-Gear Lockout". This feature will allow you to drive off the line in first and not spray until second gear! You can actually select what gear you want the nitrous to start spraying!
Dean
Old Feb 12, 2007 | 05:28 AM
So its kinda like a WOT switch and a window switch in one,and has the gear lockout feature as well? Sounds pretty good!
Old Feb 12, 2007 | 09:39 AM
Chris@NitroDaves
Guest
Posts: n/a
We offer the MSD window switch MSD Switch and we also have our digital window switch Nitrous Outlet Digital Window Switch which offers more features than the MSD. If you wanted the added option of a progressive/ window switch we also offer the FJO unit FJO Progressive.
-Chris
