Nitrous Distribution
Old Feb 12, 2007 | 09:10 AM
my number 1 hater's Avatar
Default Nitrous Distribution
When it comes to nitrous distribution, the LS1 does a great job distributing nos to all 8 cylinders with a dry kit. I would like to know does a (wet ) PLATE kit do a better job of distribution to all 8 cylinders on the LS1 or a ( wet )-NOZZLE kit ??? If there is a thread on this already please direct me to it.
Old Feb 12, 2007 | 09:55 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
The difference between our plate and a single nozzle, is the nozzle has a single discharge and the plate has multiple discharges. This will give you better atomization therefore a little better distribution.
Old Feb 12, 2007 | 10:09 AM
I can see why all the old school carb kits r PLATES ..... thanks for the INFO.. by the way whats the cost diff ???? plate vs nozzle
Old Feb 12, 2007 | 10:16 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Our single nozzle kit $499
Our 78 or 90mm Plate $649
the plate kit also gives you a very clean looking install.
Old Feb 12, 2007 | 11:30 AM
thanks
Old Feb 12, 2007 | 07:53 PM
Robert56's Avatar
A dual nozzle wet kit will give a little better distribution, than a single nozzle.
Robert
Old Feb 12, 2007 | 08:20 PM
what is the price diff on 2 nozzles vs 1 plate..... nothing else, no lines, no wires ?
Old Feb 13, 2007 | 01:41 AM
TINKRD's Avatar
#7 piston will always be the leanest.
i'd suggest a fogger if spraying and wet kit over 200 shot to be safe.
yes you can spray more w/ out a fogger, but with that much hose distribution becomes an issue, regardless if its a dual nozzle or single nozzle.
just my .2cents
Old Feb 14, 2007 | 09:14 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
yes you can spray more w/ out a fogger, but with that much hose distribution becomes an issue, regardless if its a dual nozzle, single nozzle, ***or plate***.
made a small change.
For anything above 200 there is nothing better than a direct port.
