Detailed write up on heater install?
Old Feb 19, 2007 | 06:30 PM
Breaking Stuff's Avatar
Default Detailed write up on heater install?
Ive tried search! Ive got the wiring diagram, that seems easy enough. Is there any little tips or tricks to do this nice and clean? Where did you guys route the wiring? Any info would be really appreciated. By the way its a Camaro with the bottle mounted in the spare tire well. Thanks in advance!
Old Feb 19, 2007 | 11:33 PM
99Daytona500's Avatar
May not be as detailed as you want but many people route the wiring through the grommet behind the PCM on the passenger side firewall. Then route it under the carpet along the passenger door area to the rear and then into the spare tire area. Some folks did this with their main Nitrous feed line as well I have read. Switch panels usually get mounted in the ash tray, or around the Traction Control switch area, but it's a personal preference thing. Maybe some members have photos of their installs and will chime in. Sorry I can't be of more help, as I still have to install my own heater and dry nitrous kit once I get back home.
Old Feb 20, 2007 | 12:27 PM
Thanks! I'm just trying to get an idea of where to go with it so any help is great. If someone has pics that would be excellent. Ive got the NX switch panel that goes next to the lighter socket. Everything is hooked up except my newly aquired bottle heater. Thanks again.
Old Feb 20, 2007 | 04:10 PM
WhyHelloOfficer's Avatar
I ran all of the wires to the heater underneath the passenger side carpet and inside the interior pieces on the passenger side to the heater. The ground for the heater I just tapped into the ground wire on the hatch release.
A lot of the hiding is already done with the bottle in the spare tire area anyways.
