ls1 guys an n20
Old Feb 20, 2007 | 11:05 PM
daniel6718's Avatar
Default ls1 guys an n20
what do you guys use to pull timing on the bottle?
i have a lt1 with a mallory 685 ignition box, but i dont think i t will work with a ls1 style ignition, do yall have it tuned into the pcm or adjust it with an ignition box?
Old Feb 20, 2007 | 11:13 PM
Sweet71's Avatar
Pretty much tuned into the pcm, but msd is suppose to be releasing a unit called the timing twister this month which will do the same as a digital 6 msd or the 685
Old Feb 21, 2007 | 09:25 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
There are 2 options to pull timing on the LS1, using an external box
The timing tuner....
http://www.nitrousoutlet.com/catalog...product_id=965
And the Timing Twister by MSD
no pics yet...but they will sell in the ~$275 range. Expected availabilty is mid-late March
Old Feb 21, 2007 | 09:28 AM
Bad Habit Bird's Avatar
Tuning the PCM would be my first choice.
Old Feb 21, 2007 | 04:24 PM
daniel6718's Avatar
ray, so this timing tuner does timing retard? and window swtich low/high?
im assuming by pics is uses pills?
ill probably tune in the first stage, but the second stage id like to only pull timing when i use it...
Old Feb 21, 2007 | 04:45 PM
caMnaro's Avatar
I found the msd timing twister looks preety cool. no pills just a dial.
http://msdignition.com/2007/timingtwister.html
Old Mar 9, 2007 | 04:29 PM
daniel6718's Avatar
bringing it back from the dead...is the timing tuner plug and play or hows the wiring work?
if i pull the timing in the pcm, can you use a simple msd window switch for one stage or will i need a tach adaptor?
doesnt anyone have one of these for 2 stages, timing and wondow switch?
basically im going to have 2 tages, and i want to pull timing for each with a box, and have a window switch for both...i could have the timing for one programmed into the pcm...but id rather not
