wiring question
Old Feb 21, 2007 | 11:01 AM
pushinfreight's Avatar
Default wiring question
So I am running a two stage dry setup and have a switch plate. Now I am also installing a twin intank pump setup that I want the second pump to work while the N02 is activated. So my question is do I need a relay of some kind or do I just need to splice the hot lead of the second pump to the power out from the plate to the first stage relay? If I need a relay what kind?
Old Feb 22, 2007 | 12:45 PM
Todd157k's Avatar
the reason for a relay is that there is too much current for a switch. Look and see what each item draws in AMPs. It is accumulative. Look at the switches you're using and what they are rated. Each solenoid will draw about 7 amps at activation. Some a little more. After adding up all the devices, multiply that number by 1.4 and if your switch isn't rated that high, you'll need a relay. Most N2o switches are only rated at 15A... so yes, you'll need a relay if you're going to gang anything else on that switch.
Old Feb 22, 2007 | 01:34 PM
so a 4 wire 30amp relay will work to split power to the second pump and the first stage nitrous relay?
Old Feb 22, 2007 | 02:59 PM
Todd157k's Avatar
how much current does the fuel pump draw?
