Real dumb question
Old Feb 25, 2007 | 04:58 PM
Zralou's Avatar
Default Real dumb question
I just bought a used TB plate Nitrous Works system for my LT1. The ad said "only missing jets", but I think a lot more is missing.
The kit arrived with:
10# bottle with gauge attached
Fuel and Nitrous selonoids
Main stainless line from tank to noid
Fuel line to noid
Relay
Micro switch
TB plate
2 short hard lines
My question is, where do the jets go, they don't seem to fit anywhere on what I have, is something missing that the jets fit in?
Also, what do I need to connect the stainless hose to the tank?.
This is my first experience with nitrous and i've searched here and the net but can't find any info relating to my questions.
The kit is a Nitrous Works GM LT-1 Nitrous Oxide System # 13070.
Sara Lou
Old Feb 25, 2007 | 09:06 PM
MrDavid's Avatar
can you not look up the Part number and find a picture of the entire kit and see what is missing?
Old Feb 26, 2007 | 10:23 AM
Nitro Dave's Nitrous Outlet's Avatar
Sara,
Your jets will go in the fittings comming off the plate. Then your lines screw over them. If you can lay out the kit and take a picture of it to show us. I can tell you what is missing.
Dave
Old Feb 27, 2007 | 07:56 PM
Zralou's Avatar
Thanks Dave, i've tried posting pics, but the board keeps screwing up and won't let me. I keep getting a " database error " message.
Sara Lou
Old Feb 27, 2007 | 07:58 PM
Zralou's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
Sara,
Dave
Thanks for the help Dave, I really appreciate it.
Here are the pics:
Sara Lou
Zralou's Avatar
Old Feb 27, 2007 | 07:59 PM
Zralou's Avatar
Old Feb 27, 2007 | 08:01 PM
Zralou's Avatar
Old Feb 28, 2007 | 04:52 PM
Zralou's Avatar
TTT
Sara Lou
Old Mar 1, 2007 | 07:27 PM
Zralou's Avatar
Anyone???
Help, Pleeeeeeease!!!
Sara Lou
Old Mar 2, 2007 | 05:37 AM
Zralou's Avatar
Anyone? pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeease
Sara Lou
Old Mar 2, 2007 | 05:57 AM
KrautBurner's Avatar
bottom right of pic,
there is the gold throtlebody plate,
on the left of that are the two lines (fuel and nitrous)
that's where the jets should go
I think,
goodl luck,
Russ
Old Mar 2, 2007 | 04:53 PM
Zralou's Avatar
Thanks for the feedback Russ, the 2 jets that came with the kit do fit in those fitting, but only with the taper/bowl end facing away from the plate, which to me seems upside down?.
I would have thought the end with the sized hole (tapered/bowl) would be facing the way the flow goes, not against it?.
Sara Lou
