Nitrous Explosions
Old Feb 28, 2007 | 09:58 PM
mitymikec's Avatar
Let me know if u find the site again..I will buy them..
Old Mar 1, 2007 | 02:27 AM
pist0lpete's Avatar
Well crap I payed $200 for brand new flow matched SVO #30's and thought I got a deal...
Old Mar 1, 2007 | 08:22 AM
Specialized's Avatar
Im pretty sure that anything sub-50lb is going to be in the same relative ballpark, so you didnt get taken for a ride on that one, but the 30s arent the biggest step-up from stock.
Old Mar 1, 2007 | 08:32 PM
Robert56's Avatar
yea, flow matched are generally more.
Robert
Old Feb 29, 2012 | 11:27 PM
MJs1FastSS's Avatar
Originally Posted by Robert56
Yes stock, and these guys are allways cranking up their blowers so they go bigger injectors, lots of used sets out there. Actually, I had a site that was selling new green tops for 160, but they disappeared, maybe check around.
Robert
yep that site was a great investment ..too bad they no longer do it
Old Mar 1, 2012 | 11:34 AM
karpetcm's Avatar
I bought SVO 30's for 100.00 and you can get them now for a bit more. Just depends on luck and timing. I sold them for 80.00, lol. I might just stick to dry shot then because even if i go wet i would have to upgrade my fuel pump and injectors anyway because i want to run eventually atleast a 175 shot. I might pick up 42lb injectors and Racetronix pump. The booster i have that hooks to the alternator and gives an extra 2 volts to the stock pump im sure that will also boost the aftermarket pump.
Old Mar 1, 2012 | 12:11 PM
cyipher's Avatar
Old Mar 1, 2012 | 12:51 PM
87silverbullet's Avatar
You need to invest in some glasses and see that you dug up a 5 year old thread.
5 years old to the ******* day too
Old Mar 1, 2012 | 08:38 PM
dannyz's Avatar
Owned!
Old Mar 1, 2012 | 10:46 PM
dnkynrbk's Avatar
Originally Posted by mitymikec
Hi guys, just had a few questions about the WET SHOT EXPLOSIONS I have seen..What is causing these backfires or explosions? Is it a sticky solenoid?
Is it the fuel solenoid? Shooting to low? I have always run dry shots on my car and never a problem but recently bought a TNT wet kit..Is there one brand name that is having more of this issue then others?
Would spraying a dry shot down low and hitting the wet kit once rolling by a way to avoid the explosions? What size injectors ppl going with for a 250wet shot? Thanks..MIke
I have ran a wet shot for 5 years with no issues. Its all in the Product,plugs,fuel and tuning.
I change my plugs every time I go to the track and if Im racing alot I change them between passes.
Alot of time its idiots out there who cause backfires. Using old noids,wrong plugs, cheap fuel, not retarding the timing, not using a window switch. I could go on and on. REASEARCH the stickies or call one of the sponsers on here they will help you get it set up on what you need.
Old Mar 2, 2012 | 08:09 AM
The OP of this thread hasn't been on tech in almost 3 years. His last login date was 6-6-2009. I don't think any of this is info going to be any good to him now
Old Mar 2, 2012 | 08:50 AM
  #32
dnkynrbk's Avatar
Lol I just posted in case someone had the same?
Old Mar 2, 2012 | 01:38 PM
  #33
Danger731's Avatar
Jesus aint got nothin on this thread.
Old Mar 7, 2012 | 12:02 AM
  #34
ls1 1990 VN's Avatar
