need help. where to mount relay????
Old Mar 2, 2007 | 11:38 PM
dameter21's Avatar
Default need help. where to mount relay????
I'm installing a nitro daves dry kit I have a few simple questions maybe you guys could help.
Where should I mount the relay, and where to mount toggle switch.
Also what would be a common 12v key source, ''switched power''.
any opinions appreciated. Thanks. 2000 TA A4.
Old Mar 3, 2007 | 09:19 AM
NHRATA01's Avatar
I mounted the relay on the frame rail just in front of the battery, but you can really put it anywhere, but ideally somewhat close to the solenoids.
You can put the toggle switch anywhere thats convenient. I bought a nitrous outlet switch panel that pops in the ashtray. For 12v switch, look to tap a pink colored wire somehwere under the dash. The switch doesn't have a high current load, so it can be almost anything. I tapped the pink wire at my TCS switch, and it works fine.
Old Mar 3, 2007 | 09:22 AM
dameter21's Avatar
thanks for the input.
