Opinions wanted
Old Mar 6, 2007 | 06:08 PM
BAKED's Avatar
Default Opinions wanted
Here's what I got:
Absolute speed Stage 2 heads
TR-224 on a 114
Stock short block with ARP rod bolts and ported LS-6 pump
TH-400
Edge 3800 billet race converter
9" with 3:55 gears
SFC's
LCA's
Body mount torque arm
Bla Bla Bla
I am planninnig to run a 100 shot (dry) off the line and a 100 shot (wet) once I get moving.
I'm curious to see how it's gonna run and wanted to hear some guesses and/or opinions.
BTW the car has been lightened up to around 3000 pounds.
Old Mar 6, 2007 | 06:11 PM
superchargedbandit's Avatar
So You Have 2 Nitrous Setups On The Car?
Old Mar 6, 2007 | 06:24 PM
BAKED's Avatar
Yup. 2 stages, first ones dry and the second one is wet.
Old Mar 6, 2007 | 07:19 PM
bad6as's Avatar
so aprox 400 hp na the 200 extra on n20 i dont see why 10's arnt yours
Old Mar 6, 2007 | 07:45 PM
383LQ4SS's Avatar
At that weight and depending on tires you should be low low 10s or high 9s.
I ran at 3200 lbs with a stock ls1 longblock (including LS1 intake) with a 228/232 cam el cheapo headers, full exhaust, TH400 with a 4400 stall and T brake and went consistant 10.2s at 130 with about a 150 shot dry. This was with 60 foots in the 1.37-1.42 range. Car showed about 480 rwhp thru the TH400 on a dynojet.
Old Mar 7, 2007 | 03:40 AM
BAKED's Avatar
The tires are 26 x 10.5 M/T ET Drags.
I am hoping for a low low 10 and I would be tickled pink if I could get a 9.999999 out of it.
Keep em coming
