dry kit to wet converson ?'s
Old Mar 20, 2007 | 11:43 AM
mukyluk's Avatar
Default dry kit to wet converson ?'s
so i bought a HSW dry kit about a month ago. but being the indecisive bastard that i am, now i want to change it to a wet kit. what kind of things would i need to change in the kit to convert it to a wet kit.
thanks in advance
Old Mar 20, 2007 | 11:48 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
you will need to add the fuel side.
Fuel Feed line
Inlet Fitting
Fuel Solenoid
Outlet fitting
Solenoid to nozzle line
Wet nozzle
Jets
HSW
http://www.harrisspeedworks.com/shop/home.php?cat=337
should match your existing kit.
Ours
http://www.nitrousoutlet.com/catalog...del=49&dept=11
includes fittings to work with all makes, models, and a larger fuel solenoid.
Old Mar 20, 2007 | 12:33 PM
mukyluk's Avatar
Fuel Feed line
Inlet Fitting
Fuel Solenoid
Outlet fitting
Wet nozzle
Jets
HSW
Ours
thanks just placed the order, from you guys. only thing is i wish you guys had better descriptions on your items detailing exactly what you are getting when u buy something.
