Can you buy just the neck for bottles???
Old Mar 25, 2007 | 10:36 PM
00Vette's Avatar
Default Can you buy just the neck for bottles???
I have a nitrous bottle and the neck only has the main nitrous out port and NHRA releif port. It don't have the two side parts where you can screw in a gauge or sensor of sorts.
Can I just buy the neck from a dealer/vendor and replace it? Or do I have to get a different bottle?
Old Mar 25, 2007 | 10:49 PM
Ping King's Avatar
you would be buying a bottle valve. Which has the ****, gauge ports, and siphon tube on it.
Old Mar 25, 2007 | 10:58 PM
00Vette's Avatar
Yes.............How much do they typically cost for NX bottles?
Old Mar 25, 2007 | 11:37 PM
Lythropus's Avatar
buy one from nitrous outlet, it's cheap and uses the 326 nut and nipple combination outlet found on most nx bottles. To know if you have the 326 outlet just unscrew the 4an outlet off of the bottle, if it's one piece it's a 660 or soemthing like that, if it's two pieces (a nut that tightens over a nipple) it's the 326 valve. The link posted will work for the 326 without having to buy a new bottle nut. Call them they are extremely helpful...
http://www.nitrousoutlet.com/catalog...roduct_id=2148
Old Mar 26, 2007 | 08:54 AM
nate-roth's Avatar
Thanks for the link. That is agood price, I need a couple of those.
Old Mar 26, 2007 | 09:38 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Our valve will also flow ~800hp
Old Mar 26, 2007 | 08:03 PM
00Vette's Avatar
So that'll fit my NX 10lb bottle huh?
Old Mar 26, 2007 | 08:11 PM
Robert56's Avatar
That's also the size shot Ray is running.
Robert
Old Mar 26, 2007 | 09:02 PM
Nitro Dave's Nitrous Outlet's Avatar
Yes, We also stock the NX 45 valve with ports in the side as well.
http://www.nitrousoutlet.com/catalog...roduct_id=1536
Dave
Old Mar 26, 2007 | 10:17 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Robert
single stage on a progressive controller FTW
Old Mar 26, 2007 | 10:49 PM
00Vette's Avatar
Dave
Sweet thanks! Now if I buy the 45 degree valve with side ports and the adjustable nitrous pressure switch can you toss in a free Nitrous Outlet Nitrous Pressure Guage?
I need all three to tell you the truth.
