Is a blow down tube required if ...
Old Apr 3, 2007 | 12:48 PM
ARCTICWHITE98Z28's Avatar
Default Is a blow down tube required if ...
The search function is not currently working so I'm not sure if this question has been asked before. Is a blow down tube required at the drags if the bottle is mounted in the spare tire compartment? I know that NHRA regulations require the blow down tube if the bottle is in the passenger compartment, but I am not sure if the spare tire area is considered part of the passenger compartment. Thanks.
Old Apr 3, 2007 | 12:53 PM
flames4me's Avatar
you shouldnt have much of a problem passing tech if you have the bottle in the trunk... keep the back seats installed though. is the car (at least the interior) mostly stock?
Old Apr 3, 2007 | 12:59 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
with a stricy interpretation of the rules ....yes you will need a blow down tube.
if there is not a sealed bulkhead in between the passenger compartment and the bottle you will need a blow down
the GTO's are also required to have one even if the bottle is in the trunk as the passenger compartment is not sealed off from the trunk
